Nothing is ever easy!
JBlubaugh
I spent a chunk of the weekend pulling out the old radiator, hoses, belt, and pulleys. The plan was to replace all the rubber parts with new fresh ones, clean up and wipe out the accumulated road grime on the front of the engine, and drop in a new radiator ( Wizard Cooling). Everything was going great until I tried to drop in the new radiator, it doesn't fit! :mad:. Sits about 1/2" too high and will make contact with the hood.
Before I blame Wizard, I need to check a few things. The front end internal geometry has been modified by the PO upstream from the results of a crash or two. Odd thing is the old radiator fits, unless it has been modified.
Does anyone here happen to have the dimensions for a 3000 radiator?
Worse thing that happens is I could make 2 small drop down brackets and only use the upper mounting nut on the bottom part of the radiator. That would drop it down and provide clearance.
Thanks for the vent and the help.
Jim
Keoke
Hmm
Jim If the old radiator fits.
Measure the spacing between its mounting brackets and the new Aluminum one
If they are different.
Perhaps the front end repairs placed the chassis radiator mounting brackets at a different location???
J
JBlubaugh
Thanks Rick -
That's what i am getting on this one as well.
From the top of the top tank (not including the filler neck) to the bottom of the bottom tank is 21 3/4" which is the same height Wizard provided in the drawings of the radiator they made for me.
HealeyRick
Thanks Rick -
Did Wizard send you a drawing of your radiator before it was made? If not, PM me your email and I'll send you the one I received. Although there will be some differences in the depth measurements with mine and a standard radiator, the height, width and bracket locations will be the same as a stock one. If the height of yours is equal to the stock one, then the only thing different on the Wizard radiator could be the bracket locations. Do you have pictures of the radiator mounting points on your car, so we can see if they were changed after the crash repairs?
J
JBlubaugh
Thanks Keoke -
That's my next assumption. If the specs from wizard are good, and they appear to be, my money is on the brackets on the original radiator having been moved. I'll have to wait until the original comes out of the shop. I had it cleaned up and restored for a BT7 project ( my Fathers original Healey) that i'll start in October.
Thanks,
Jim
Hmm
J
JBlubaugh
Follow-up
Ok, after trying various positions of the radiator I was able to find a combination that allows the hood to close and the gives good clearance to the fan. The problem lies with the top left mounting bracket on the car. Looks like a previous repair has the bracket slightly out of position by 1/2 inch. The only problem I have is that I cannot secure the radiator to this bracket. I don't think that will be an issue as I have it mounted with 5 other bolts. It is also slightly askew which is driving me crazy, but is totally functional.
Not sure if modifactions were made to the original radiator, will have to confirm when I get it back early next week.
attachment.php
J
JBlubaugh
Side view showing the slight mis-alignment.
attachment.php
J
JBlubaugh
Could you move the driver's side forward to square the radiator to the front and drill a hole in the radiator support to match the hole in the bracket on the radiator? There's plenty of metal in the support in that area.
I think that is going to be the cleanest way. Will have to drill out holes on both sides to match. Now to wrestle it out :smile:
Thanks,
Jim
HealeyRick
Thanks,
Jim
Cover the fins on both sides with cardboard first, they dent really easy and you're almost certain to nick them somewhere during the Wrestlemania. I like to secure the bottom hose first before bolting the brackets on, it seems a bit easier than trying to get it on later.
J
JBlubaugh
Good idea Rick - Thanks
Jim
J
JBlubaugh
Took it out for a nice drive this morning through early afternoon, temp never got over 190. Best part was sitting at the traffic lights and not having to worry about getting some air to flow over it.
Sidenote- The Denis Welch fan is great. The reduction in fan noise coming from the engine was worth the hassle alone.
Thanks for all the help, especially Rick and Keoke.
Jim
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
T Post-War Other Nothing's easy Triumph 6
E General MG Besides falling in love with my new purchase - I know nothing about MG Midgets MG 7
S Nothing like a cloudburst... Spridgets 19
T Anything or nothing. Austin Healey 3
J Got my Heritage certificate but nothing new came on the sheet British Motor Corp 2
G HELP!!! We have suddenly have NOTHING to drive! MG 44
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
B Nothing to see here,pic attach attempt MG 7
2wrench Aint nothing happening on the rebuild Triumph 35
B Nothing mellow about this yellow Austin Healey 1
H Brakes done, nothing new there. Have a rocker ? Spridgets 5
G I don't trust nothing I can't see...electricity Triumph 4
G So I have nothing better to do Triumph 17
J TR4/4A TR4 won't start, won't turn over, nothing. Triumph 15
S Wedge TR7 1, Sam nothing Triumph 4
TypeRboy Wellthere's nothing for it... The body comes off! Lotus 3
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
Jim_Gruber Remember "The Mite" a beautiful "almost a BE" Build. It's back on BAT and Badder than ever! Spridgets 6
R TR2/3/3A Best day ever [so far] Triumph 1
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
Jim_Gruber Boy was I ever surprised on Saturday Spridgets 11
T Was Sophia Loren ever photographed with a Healey? Austin Healey 2
S Scam or greatest deal ever? Decent BT7 for $15K? Austin Healey 9
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
PAUL161 General TR If i were to ever own a triumph Triumph 10
J Cloth interior in AH-3000? Was it ever fitted? Pleated inserts maybe? Austin Healey 7
Pythias Back and Better Than Ever. Spridgets 7
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
Jake Anyone ever get into their horns? Austin Healey 6
L If you ever wanted an Innocenti... Spridgets 15
Elva164 Videos from my first-ever weekend at Watkins Glen! Racing 4
M Ever seen this ? - early wire hubs for drum brakes Spridgets 10
bigjones Ever re-paint your license plate? Spridgets 22
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
T General TR Ever wonder why 87mm is a favorite size? Triumph 6
L What is the rustiest, most run down Healey you have ever seen? Austin Healey 56
DanLewis Anyone ever installed a Mercedes hood vent on a Bugeye? Spridgets 5
Basil TR6 The "blokiest" Bloke's car ever built Triumph 12
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
S Were Valve Covers Ever Painted Blue? Austin Healey 8
B Anyone ever buy from these guys? any feedback? http://www.northwestimportparts.com Spridgets 6
DerekJ Ever seen wire wheels like this before? Austin Healey 5
glemon Ever seen these wheel covers? Spridgets 5
Nunyas The coolest jackstands I've ever seen Restoration & Tools 3
dougie Ugliest Healey Ever... Austin Healey 8
Mickey Richaud Ever Seen... MG 7
