The "pump" (compressor) goes on the motor and that unit has the two lines required for high and low side. It could be a heater core assembly but that's a lot of trouble to go through just for heat. A shot of the cut ends of the lines will tell for sure.
It may or may not. If it is a/c I dig the way it appears to discharge through a port instead of a grill. That would make it easier to adapt to almost any car, just pumb into the existing dash vents.
