jlaird
Now I know that the four bolts in the cockpit related to the springs do. Nothing really, just more support for the spring hanger that is welded in.
What happend is I got the two bolts on the U hanger around the spring off, then promptly broke the two front bolts, now that should not be a prob you would think but they stick out just enough that the spring while loose now will not come out. There is just not quite enough room.
Thinking.............
Maybe I can disassemble the spring in place from the bottom up. Will have to cut the spring plates off of the spring. If I can get the darn thing out I am home free.
