I recently removed the side exhaust actually and went back to the standard pipes. My dad - whoās the one enjoying the car really - couldnāt take the noise, ha ha !Replacing the felt might help some, but most of the noise is the panels of Perspex rattling against each other. There really isnāt much you can do about that.
I partially solved the problem by installing a side exit exhaust. It masks the noise.
To remove the Perspex on yours, I think you will have to disassemble one of the lower frame corners.
Thank you Michael. We put little pieces on foam-like material and it helps. Would you have a picture to illustrate what you suggest?Putting a piece of aluminum channel over the vertical edges of the panels will keep them from flexing and rattling.
I have the rattling problem only on the highway. I then put just a Kleenex-tissue between the two Perspex.The side screens on my BT7 are shaking and rattling. Am new to Healeys. Any fix?
I thought of replacing the felt in the rail, would that solve the problem?
And if yes, how do you get the Perspex out of the frame?
Haha, even cheaper than my foam technique ! ThxI have the rattling problem only on the highway. I then put just a Kleenex-tissue between the two Perspex.
Thanks a lot Michael. Interesting solution. It looks pretty good !I am attaching a pic showing the AL channels I glued to the vertical edges of the side curtains which stiffen them and keep them from rattling. The curtains are not stock and came from NICAL Engineering in the UK along with the hardtop, but the concept can be used on any side curtain.
BTW I had the side curtain brackets made by a machinist and I tapped the stock door sockets so I can screw the curtains to the door, providing a rigid mount and preventing the curtains from flopping around whether the door is open or closed. The seal both to the door, the hardtop and at the windshield stantion is pretty water tight (for a Healey) when the doors are closed and the curtains do not pop out at speed.
