Noise coming from my '89 xj6's rear
Fixed!, and here's how:
"There are several errors in the diagram you referenced, AND the Jaguar
Parts Catalogue for the 89 model is also WRONG in that it reverses the
position of the bearing spacer and adjustable spacer. The way the hub
is made, "necked-down" with a smaller diameter on the inboard end, you
MUST put the large spacer on first, with the small end inboard, and
then put the thin "adjustable spacer" on inboard of the large spacer.
The function of the two spacers is to provide the proper space between
the inner and outer bearings, and the thin "adjustable" spacer (which
is available in different thicknesses) provides the proper end float of
the bearings. If you didn't replace a hub carrier (just the bearings),
then you can use the same spacers, as long as you assemble them the
correct way.
So to make sure the above is clear, the following is the way the
diagram you linked SHOULD read:
(1) The component labeled 1-26 is the bearing spacer, NOT the
adjustable spacer, and it should be assembled on the hub shaft, large
end first, or large end on the outboard side.
(2) The component labeled 27,28 on your diagram is the "adjustable
spacer" which is available in different sizes. That small spacer is
assembled on the hub shaft AFTER the large spacer, fits against the
SMALL end of the large spacer, and is followed by the Inner Bearing.
Thus the two spacers set the distance between the two bearings.
If this isn't clear, please post back, as it is IMPERATIVE that this be
assembled correctly.
George Balthrop, Clifton, VA USA
85 & 89 XJ-S Coupes; 89 XJ40 VDP"
AND
"In reply to a message from Tophatchef sent Sun 29 Mar 2009:
The spacer you cite goes inside the hub carrier between the
two bearings.
You need for first install the outer bearing and seal then
slip the splined hub into the outer bearing.
>From the other side, install (only goes 1 way) the inner
spacer then the bearing, then the seal.
Slip the inner hub/abs ring carrier into it's bearing and
then slide the axle shaft through to the outer hub."
"the Jaguar
Parts Catalogue for the 89 model is also WRONG"
Yeah, well, we've never seen that before, have we?
Rule of thumb:
Take ONE side apart.
If it falls all over the place, then you can CAREFULLY, and maybe with an assistant, take the OTHER side apart to see where the parts are.
I was on the verge of taking the other side off, the only reason that I didn't was because my assistant and I (I was really more the assistant), but anyway, we were worried about having the problem of not being able to align the spindle, and of getting more sand in the area, and ruining those bearings. Well, maby I'll replace the other side next week or so. I've had enough for now.
By the way, the noise is still there. I'll take it to Eco Lube another day, and see if they can check the diff. oil. I can't seem to find it.
