I have no turn signal working on my front left side, but the side marker on that side is blinking very fast. I thought that usually meant that a bulb is out.
All bulbs work, and the bulb on my front left side tests good when I pull it and connect directly to a current.
It wouldn't seem to be a flasher unit problem because that side marker light is blinking fast (too fast)and getting current.
Is it more likely a loose or disconnected wire, or bad ground? Other ideas?
As usual, thanks well in advance.
