Sopwith_Camel
1968 mgb.
the car has always started right up.
i was at the shops the other day got back to the car turned the key and nothing, no clicking from the starter solenoid. i poked at the wires under the hood. and at the white under the dash. and then it started.
i got it home and tryed to tighten the wires at the solenoid but the nut just turned and wouldn't cinch down and make a good electoral connection, so i order a new one.
I put the new solinoid in yesterday cleaning up the contact from the solenoid to the starter.
I got power back but Im still not getting anything to the starter.
I checked the ignition switch, the battery kill switch, the wire from the ignition to the solenoid.
oh this solnoid had an extra small spade connector I use the one closest to the main contact where the power comes in from the battery.
when it stops raining i will go out and try to re run the line from the ignition.
