I posted earlier about the coil problem. I changed the coil today. The new coil is by Stadard and does not require a ballast resistor.
Now I do not have any spark at all. Not from the coil and none across the breaker points. I checked all of the connections in the dist. I have 12 volts at the positive side of the coil. The resistance across the low voltage side of the cois is 3.8 ohms. (I checked with two different meters)
What next????
What next????
