terriphill
OK, wiring harnes is installed and connected (we think) there is voltage to the starter, it is turning over. There is voltage in the wires going to the new coil (we checked it) But, no spark to the distributor. It seems to be a bad ground but we can't seem to trace wherer it would be.
When we got the car it had burned wiring in the harness and the DPO had completely bypassed the starter and direct wired a push button start, so the pictures we took about how it was connected. We did install electonic ignition and bypassed the plug that is supposed to plug into the distributor. Any ideas about what we should be checking?
I am thinking about just investing in a new wiring harnes and starting over from scratch....could a ground wire be bad in the harness? We installed new electonic and ignition switch, ignition, rebuilt starter, new coil.
I just am not getting any spark.
Hi Guest!
