Hi, Just some info, after working on my '76 B most of the day "making adjustments" that the wife didn't seem too thrilled about, I talked her into a ride! Well about two blocks away from the house I noticed no running lights! So after "the look" we returned home, well to make a long story short and to maybe save someone a little trouble, after checking all the usual, fuses, connections etc; it winds up being the headlight switch! I was able to remove the switch, take it apart, tighten up the rivets, put it back together and presto, everything is working fine! MACK /ubbthreads/images/graemlins/cheers.gif
