Woodie
Iam running twin su's on a 1275 engine, I am trying to get it to run after 2 yrs. Replaced all igition wires, cap rotor etc. Cleaned out the float bowls, made sure dampers moved freely, and the needles and butterflies were not stuck. Set the idle screws at 1 1/2 turns and the mixture down from the bridge 2 full turn on both carbs. The car starts and idles about 1700, but when I pull the throttle cable there is NO increase in engine speed. NONE???? The damper move up, then settle back down, the cable is connected cause the butterflies open.....any suggestions??
