Good morning to all of you,
I'm still rebuilding my 1964 BJ8, and I have to say the problems are piling up. While some have been fixed, there's a new one that's intrigued me, and I'm asking for help because I'm stuck at this point.
First, I have no idea if there was any pressure because the original gauge wasn't working.
So, I bought a new gauge, and it works because the temperature is showing.
I removed the hose to check if it wasn't clogged: nothing wrong with the engine starting
I removed the hose on the engine block: nothing wrong with en engine starting
While reviewing the forum's posts, I read that the adaptive cartridge filter might be installed incorrectly. I removed the filter and noticed that it was installed correctly. I inspected the filter and noticed that it wasn't with oil, which didn't seem right to me.
Before putting the original filter back on, I turned the engine and noticed that oil was coming out of the hole. (I had to clean…) So the pump seems to be working, or maybe it's the crankshaft's movement that's causing the oil to come out.
I put the old filter holder back on and check if the oil is coming out of the pipe: I ran the engine and nothing.
Then, okay, I'm out of luck
What could be wrong, what can be the problem? Thanks for your advice.
Have a nice day
Marc
Have a nice day
Marc
