Symptom:
Turn the key this morning and turned over and over then stopped turning and no power period. Made sure that the battery cables were tight. Looked over some wires and turned the ignition back on. Fine. Turned over the engine for a few more seconds and then nothing. No electric pump ticking. No ignition light. No starter turning.
Tool a few minutes to check the wires behind the instrument panel and then turned the key. Fine. Turned the starter for another few seconds and then nothing. Repeated this cycle of events a few times more. Battery was just charged over night and when it is working the fuel pump sounds alot quicker and stronger than it was before. Two electrical changes that I made since it was running fine were to replace the headlight foot dimmer switch with a generic one from napa. Also put in a Petronix ignitor in place of the points.
I should have done one at a time I know. When it is not turning on my test light does not see any power at the switch. The two fuses are fine. Other than putting that points back in and putting the headlight dimmer back in, to get back to exactly where I was electrically can anyone advise me on what your next move would be?
Thanks very much,
Jim Lee
Thanks very much,
Jim Lee
