My '60 BN7 has been out of action for a couple of weeks. Tonight, as I planned to test some brake work, the car would not start. Not a pop. Since I learned on this forum how to correctly adjust the choke, it has never failed to start. First, I let the fuel pump run for several minutes, pulled the manual choke, and couldn't get a pop. Checked the glass filter bowl ahead of the carbs and noted it was half full. Tried starting fluid. Nothing. Pulled a plug, no gasoline. Loosened the rear carb banjo fitting, and gas spurted. Even at that I'm not smelling gasoline in the engine bay. Tightened the banjo and turned over some more. Pulled another plug. Dry. As I had just installed a brake servo with a fitting on the intake manifold, I disconnected the servo hose and capped the manifold fitting. No difference. This car has a Pertronix (sic) electronic ignition. I would have suspected I am not getting spark, but as there is no gas on the plugs, I didn't try the spark test. Yet, there is gas in the line to the carbs reaching all of the way to the banjo at the back carb. Solutions?
