I recently completed the resto of my TR6... now it just sits hibernating through the long cold winter. I just started it up and let it run to operating temp.
The problem is that I do not have any heat in the cabin. After it got up to operating temp. I pulled the cable to open the water valve then went and felt the top hose going into the heater core.... it was stone cold. Right now I suspect that the water valve is not working (it was replaced with a new one when I did the engine).
So, my question is what is the best way to test the valve?
My thought was to undo the top hose at the firewall connector and then slowly open the water valve.
Is this the correct way? Is there a better way?
Baby it's cold outside.... and in!
