what makes the coil spark?
I tried to crank my 74B over the weekend with no luck, it was running a week ago. I am not getting a spark from my recently purchased sport coil. I checked the wires going to the coil and have 11 on the positive white wire and 2.2 on the negative white black wire. I even put my old, working, coil back on and no spark. The only thing I have done recently is change some bulbs on the gauges and check the gap on the points. The points were fine so did not have to adjust. The rotor button appears to only go on one way and I checked to be sure it is on good also. I tried the orginal coil wire as well.
I have checked all I know to check and am looking for any advise as to what to check next.
Thank you in advance
Greg
Greg
Hi Guest!
