TR4/4A No dash lights! Or any of the gauges.
Zitch
I have 12 volts at the rheostat but none of the lights lite. I"ll start the digging. Any where else I should be looking?
Zitch
TR3driver
Great Pumpkin - R.I.P
Did you check on the output side of the rheostat, with the wires connected?
If there is still 12v there, I'd look at grounds next.
NutmegCT
And you cleaned (file and/or sandpaper) the bulb ends and bulb sockets? Corrosion/oxidation builds up over the years. And of course, are the bulbs good (VOM shows continuity)?
Tom
texbears3
Rheostat copper contacts get oxidized. I had to take mine apart, clean it really good. Rheostat works great now. Previous owner had put 7.5 volt bulbs in every guage, and all of them blew-out. It's a pain to replace them with the correct 12volt bulbs.
Healey_Z
You are real close knowing here is 12v to the rheostat. Since none are working,I suspect your switch.
Funny story. I was with a pilot buddy last week and the light on the oil pressure gauge wasn't working. He tapped it with his finger and it started working. He said huh, just like an airplane.
DNK
More concerned about the instant smores maker that many have had
DNK
A few have burned
Have a pic from a friend somewhere buried in the archives.
jfarris TR2/3/3A Dash Lights Triumph 3
K TR2/3/3A Dash Lights Triumph 3
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A re- solder my dash lights Triumph 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
Marla TR4/4A Led dash lights Triumph 0
P LED Dash Lights Spridgets 1
gbtr6 TR6 LED Dash Lights Triumph 8
B Dash lights fused? Austin Healey 3
J Turn signal dash indicator lights Austin Healey 20
C Dash lights Spridgets 14
F Spitfire Spitfire 1500 Dash Lights Triumph 1
I Solution for brighter dash lights? Triumph 14
I Dash Lights Austin Healey 1
K TR2/3/3A TR3 Dash lights:Conversion to green bulbs? Triumph 3
R BJ-7 lights on dash. Austin Healey 4
veale001 Dash Lights Failure. A first I know... Triumph 12
Ofcalipka Where can I obtain dash lights and switches from. Spridgets 18
Atrus '68 Dash Warning Lights Spridgets 7
Don_R Dash lights Triumph 3
RickB Courtesty, dash & trunk lights - commonality? Spridgets 5
eejay56 85 Honda dash lights Other Cars 6
G TR6 TR6 dash lights not bright enough Triumph 22
RickB Dash Lights - the Good Lucas Fairy has visited!! Spridgets 9
73MidgetLigon Dash lights Question MG 6
B Turn blinker lights in a "pillow-dash" Spridget Spridgets 0
M Dash Lights Jaguar 1
hondo402000 LED Dash lights Triumph 15
S TR2/3/3A Wiring for Dash Lights - TR3 Triumph 6
D TR4/4A TR4 Dash Lights Triumph 7
GlennLBC Midget Dash Lights Spridgets 10
S Dash lights MG 5
S Dash Lights??? MG 9
tahoe healey dash lights Austin Healey 8
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
