Alex_McMillin
Ok, next up, the horn. I'm not sure I fully understand exactly what makes this thing work, or in my case, not work. I have installed a couple of conductor wires to hop over the rubber flex couplings on the steering column, but still no luck. Now, I know both horns work. I can ground them individually and they work. So, here are my questions. Firstly, what is the horn button actually supposed to ground to in order to produced sound? Secondly, is it simply that the contacts I have my conductor wires connected to a not clean enough? Finally, do I need a third conductor wire from the bottom of the steering column to the frame?
Any help, photos, etc. would be much appreciated.
...........Cheers, Alex
