As I finally figured out my brake woes (after rebuild) I fired the TR6 up for the first time in 5 months. The engine was rebuilt last summer/fall & I have about 400 miles on it.
Problem 1. Looks like I have some oil running down the left side of block in one or two places. Coming from head gasket?? Does that sound likelely? (the engine is so fresh that I'm at about 90lbs. when under load before fully warmed up). If so what's going on? Also, when driving I saw the oil light flicker for a few seconds but pressure was good (high) and level ok.
Problem 2. I also noticed this once last fall. Engine runs great and is very responsive. However, when I shut it down for 5-10 min. and restart it wants to stall, sounds like the exhaust has a mute on it (Ansa exhaust), and needs nursing to keep it running until i can get going, put it under load, etc. Then runs well and can come to stop & get ok idle. Today I opened the hood after getting home and front carb was dripping gas pretty badly. I assume stuck float--would that cause other stuff mentioned?
UUGHHH!
UUGHHH!
