Not sure I understood but if you press the pedal and it goes solid then slowly goes to the floor there is a leak. If you don't find any sign of external leaking then it would be inside the master cylinder. I don't remember whether you replaced or rebuilt it. If you have to pump the pedal to get pressure then that usually means you need to adjust the shoes more. Also bleeding brakes will not cause them to need further adjustment though. Finally, a "mushy" pedal is usually a sign of air. As Jim said, "bleeding ... is challenging."
