rjfoster03
Recently purchased a 66' Sprite and have a few questions.
In the process of changing all fluids, tune-up, etc... When I pulled the plugs they are sooty black. I know that the prior owner used the choke more than I would think it should be used when driving. I am assuming that it is running rich due to the coloration of the plugs.
The car does "gurgle" / backfire upon downshifting / slowing down.
I am thinking that the carb needs to be tuned and if like my motorcycles, re-jetting is in order.
Am I correct on this?
If so, I need to know what is the best way to handle the re-jetting. I have done this on a honda motorcycle, but the carb is a little different.
<span style="text-decoration: underline">From what I see on the carb:</span>
InterC
Serial # 009541
DGV 5A
32 36
1. Can anyone tell me about the carb that I have?
2. Is this best to have someone "qualified" to do this if I am mechanically able?
3. Best way to select proper size jets?
Thanks for any help.
InterC
Serial # 009541
DGV 5A
32 36
Hi Guest!
