Hi everyone. This is my first post . I'm a Triumph Fan since the early 80's, own a TR3A & TR4 which need to be restored. I've also owned a Spitfire 1500 that I enjoyed immensely but I'm really looking forward to restoring the 3A. I've waited 20+ years to start, the frame is stripped and ready for paint now, yes I'm excited. Just lately I had the opportunity to help with the restoration of a 3A which has motivated me to start my restoration. At the moment I'm helping a friend who has a 66 TR4A. It had a leaking needle&seat on the front ZS carb, fixed , put in new ignition,points,condenser,rotor,cap & wires, adjusted valves and carbs. The engine runs great on acceleration and has a decent idle but when you raise engine speed slowly to between1400-2000, it really jumps around alot but smooths out at higher rpms. Also, when driving in 4th gear at speeds of 40 mph or less, the car lurches back and forth mildly instead of just pulling consistenly,sort of mirroring the fast idle jumping around I mentioned earlier. I know that the engine was rebuilt once and was wondering if maybe the timing chain tensioner missing or broken could cause these symptoms?
