    Thanks and welcome to BCF!
Newbie from NH with a 1973 spitfire 1500
ScottFromNH
Hi everyone.
my name is Scott. I just purchased a 1973 spitfire to restore. I am hoping that I can pick up some knowledge from this site as I have never owned a british car before.
I do have one question.
On the SU carb that is on the spitfire what is the black knob at the top of the carb for? I heard someone mention to me I am suppose to put oil in that? Is that true and why?
scott
Welcome Scott!
That is correct, put some oil in there to help lube everything. I use Mystery Oil in mine, and add some every once in awhile when I see that it gets low.
Best of luck on your restoration!
Hello, Scott, and welcome to the party! You'll find lots of help here, as well as some great folks to get to know.
As for the black knob, yes, that's the cap to which a plunger is attached. The plunger is dampened by light weight oil, which gives resistance for the piston....
Here, this says it much better:
https://www.teglerizer.com/sucarbs/techtip6.htm
Happy reading! And let us know how you get on. Don't forget pictures.
:cheers:
Mickey
Hey Mickey,
Thanks for the link it will be interesting reading I am sure. It might even help me when I try to rebuild my carb.
SU's are an easy rebuild. The only tricky part is if you have to rebush the throttle shafts. Whatever you do, DON'T mix up the pistons and chambers on dual setups; they're matched sets.
Hi Scott, and welcome to the Forum! :savewave:
Howdy Scott,
"Welcome" to the BCF. Surely "THEE" very best place for Yourself & Your Spit to meet a whole bunch of new folks that are ready & willing to help you out in any way they can.
Have Fun & Enjoy Your "New/Old" ride.
Russ
