New Wiring Harness
duplaga1952
I have a 1968 Sprite. When I purchased it, the wiring harness was clipped off 1 foot beyond the firewall.
New wiring harness - as the harness goes to the headlights it branches off: at the end of the branch is the big brown wire with the yellow stripe, and little brown wire with a green stripe to the generator. Back up the branch is a single white wire with a black stripe. Four more inches up the branch are two wires - one white, and one white with a black stripe. Then comes the black wire with white stripe to the brake failure pressure switch.
My question is: the three wires between the generator and the brake failure wires - where do they go? Any help would be greatly appreciated - then the harness will be complete.
Thanks - Bob
White goes to the + on the coil
White/black goes to - on coil, the other end of that w/b wire goes to the distributor.
