I started wiring the BE last night, like most I started with the dash items.
Fuel- check
Spedo- check
Taco- check
Oil/temp- check
Turn Signals- check
Ign Multi switch- check
Wiper switch- NO CHECK
Heater Switch- NO CHECK
I think that I have the wiper switch figured out for the most part. I have the brown/green wire from the loom there but the problem is that there are three solid black wires, all running to different parts or the harness. I'm sure that I need to use one of those to ground the switch.
On the heater switch I have one leg hooked to the group of green wired on the loom where a bullet connector is. Does the other leg of the switch hook directly to the heated through the firewall of does it go through the loom somehow? Possibly the green/brown wire?
Maybe I was just tired last night and will have better luck tonight. It can't be to difficult as there aren't that many wires. But the three solid black wires didn't make a lot of sense to me. Seems they should be color coded if they are for a specific device OR they should all run back to a common ground point.
Fuel- check
Spedo- check
Taco- check
Oil/temp- check
Turn Signals- check
