New wheels and tires for Penny
drooartz
I probably should have started with other parts, but I just couldn't resist. Got 4 new dark grey minilites from Moss and had some new 155/80/13's put on. My flimsy justification is that I want the final wheels and tires as I redo the suspension and convert over to front disk brakes -- to make sure everything fits you see. Yeah, that's it... 😁
Saw these on another Bugeye at a local show this summer and it finalized my decision. They really are helping to get me motivated to start the reassembly and rebuilding work. Took a few minutes today to reinstall the VIN plate in the engine bay and the number plates in each A-pillar. Small things, but still necessary.
Once the Morris is back together and off the lift I'll pull the rear axle and get to work.
drooartz
drooartz
Looks great! Your panel gaps are awesome!
Paying someone to do the bodywork wasn't cheap, but I have to say that they did an excellent job. The car wasn't too bad, but there was rust to contend with.
Now I'm just paranoid that I'll scratch it while I'm putting it all back together. :eek::smile:
(maybe more along the lines of I'm just really careful)
Bob Claffie
Snicker snicker, you'll have to pick up the pace or those tires will age out before you're done.
drooartz
drooartz
That's part of the motivating factors. :thumbsup2:
drooartz
drooartz
Agree w drooartz you've got to do that occasionally to keep yourself fired up. Looks very nice!
I really like them. Can't always be practical, sometimes you need to pull the emotional move to get things going.
SaxMan
I've been thinking about going the Minilite route. While Baby Blue's steelies are much better than they used to be since I had them straightened, I can still get a pretty serious vibration when the wheels are out of kilter with each other. I've been contemplating taking B.B. over the Chesapeake Bay Bridge to visit my daughter. It's 90 miles door to door, with a large portion at highway speeds. I could imagine dealing with that vibration for two hours wouldn't be a lot of fun.
I was thinking of going up to 14s and running 70 series tires. I mean, if I'm going to go through the expense of replacing the wheels and tires, might as well go big :smile:
drooartz
drooartz
I'm a big minilite fan. I know they're the obvious choice, but they do look good. Had I all the money, I'd love to do some custom Dunlop style alloy wheels like used on Jags, but that would indeed take all the money.
I stuck with 13's on the Bugeye (with 155 tires).
No matter what size, modern/new wheels are a good thing for peace of mine and smoothness of cruising. :driving:
SaxMan
Is the wheel vibration from them being balanced on a Hub Centric machine not Stud centric?
David
It was a case of 50 year old wheels that have seen their share of hard hits. My car began its life in Chicago, Illinois and I imagine it ate more than a few potholes there. The only time it becomes an issue is when the flat spot on two of the wheels are synchronized with each other. It manifests itself with the steering wheel jiggling. It's manageable, but annoying.
Jim_Gruber
If you have a SWA Sprite you are limited in the rear how big you can go 155/80/13 is about it. Fenderwells get in the way.
Jim_Gruber
Drew, Were you able to get those wheels to fit, they look great BTW, without adding Spacers. My JBW Wheels, the ones that MOSS Sells, needed 1/4" Spacer in the back and 1/8" Spacer in the front to clear the Tie Rod End. Not sure of the offset in my wheels but I did need to change to longer wheels studs purchased from Winners Circle. In the rear I only had 3-4 threads available to tighten and that is not enough thread to ensure you aren't going to lose a wheel/Break a wheel stud.
drooartz
drooartz
(sorry, been away for a bit)
The wheels are from Moss (Minator), and seem to fit perfectly fine with no spacers. When I change over to discs in the front I may have to file down the tie rod ends a bit for clearance, but don't expect that will be too difficult. Currently still on front drums. Running 155/80/13 tires.
I will be changing the rear backing plates to the later ones as well, so we'll see what's needed if that shifts anything, but I don't expect it will.
Platinum
In the vernacular of true LBC enthusiasts: "Cobble to Fit"!! (y)
drooartz
drooartz
Absolutely, Doc! There's always a bigger hammer...
B Wheels and Tires Selection Austin Healey 10
F TR6 Wheels and tires Triumph 10
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
Joe Schlosser Wheels and tires Spridgets 15
Jim_Gruber New Wheels and New Tires for Bugsy IV Spridgets 5
K TR6 Wheels and tires Triumph 3
S TR6 new wheels and tires Triumph 18
BN6_2197 185/80 tires on 15'' wire wheels in Germany Austin Healey 10
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
RJS TR4/4A Questions: new tires on old wire wheels Triumph 10
tr7andtvr Wedge Wheels and Tires? Triumph 13
N What size wheels and tires for flared fenders? Spridgets 7
58Custom Who can mount tires & balance wire wheels in LA? Spridgets 5
Rut New wheels arrived, which tires? Spridgets 3
M Use of Tubeless Tires for Early Sedan Wheels Jaguar 0
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
Hoosier MGB Nearly new Tires plus wheels for MGB MG 8
M wheels, tires, and tubes Triumph 8
J Inexpensive way to ship tires/wheels Triumph 10
Tabcon Wheels-Tires-and Bell Bottoms Triumph 15
KVH TR4/4A Tires and Wheels on a TR4--A follow Up Triumph 9
pjsmetana Spitfire Spitfire, Wire Wheels, White Wall Tires... Triumph 26
T what max size tires & wheels fit a tr4,tr4a,tr250? Racing 3
Y TR4/4A '64 TR-4 tires w/ wire wheels Triumph 6
M europa,wider,lower,tires,wheels Lotus 0
A Tires and Wheels? Austin Healey 2
mjobrien New Tires and Wheels for BN1 Austin Healey 8
C How do you ship wheels and tires? Triumph 10
Baz Wire wheels, tires and tubes.... Restoration & Tools 7
WidespreadPanic New wheels & Tires Triumph 24
Y TR4/4A TR-4 Wire Wheels & Tires Triumph 6
S Wheels and tires for a BJ8 Austin Healey 15
D TR2/3/3A Free TR3 wheels, tires, hub caps Triumph 4
jlaird Something else to think about, Wheels and tires. Spridgets 1
R TR4/4A whitewall tires on spoke wheels TR4A? Triumph 8
PAUL161 MGB MGB Wire Wheels & Tires MG 7
mrstinson Wheels and Tires Spridgets 13
martx-5 Wire Wheels and New Tires Triumph 5
J Wedge 14" wheels, tires for TR7 Triumph 0
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
