TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl
Federalees
Hello!
I am new to this forum and wanted to make my introductory post. I recently acquired a 1967 TR4A IRS and this forum has been a wealth of information. Thank you for that! In this post I figured I would relate a problem that I resolved that seems pretty common based on other posts that I have searched. However, the resolution to the problem was one that I had not seen.
I recently smelled gas in then garage and noticed fuel seeping from the fuel pump, so i decided to rebuild it. Easy enough, but once I reinstalled the pump and started the car, I noticed a lot of gas weeping from the vent hole of the back carburettor. Assuming that this was the actual cause of the gas smell and I hadn't notice it before, I checked floats on both carbs for adjustment and leaking but they were fine. I replaced the needle and seats on both carbs along with the floats for good measure and none of this solved the problem. This was driving me a bit bonkers. I spoke to everyone I could find that was an expert on SU HS6 and searched this forum for the answer but was unsuccessful. So, back troubleshooting 101. What changed? The only thing was the rebuilt fuel pump. I checked the pressure from the pump and it was at 7 PSI !! Instead of pulling it apart again, I replaced it with a new pump. Problem solved! (face palm). So now I am wondering what I did wrong in rebuilding the pump that would cause such high pressure. Any ideas? Has anyone had this problem? The kit came with the diaphragm gaskets, and check valves, which I have double checked and they are installed properly as far as I can tell.
Platinum
This is just a W.A.G. on my part, but about the only things I can think of that might affect output pressure on those pumps is the springs. The diaphragm spring may be weakened over time, the aftermarket check-valve replacements may have less-than strong enough springs.
But again, just a guess.
TRopic6
The closer the pump is to the block (& the cam), the more stoke it will have. Was there a thick gasket (or several) between the pump body and the block? I had to use a non-AC replacement pump for my TR6 and the output was ~5 PSI. I cut a gasket out of 1/8 material and brought it down to ~3. It worked OK but I did rebuild the original AC pump with a kit from Then & Now. They use really good check valves (+1 on replacement valves leaking).
charleyf
The "weep" hole you refer to is actually the overflow from the float bowl. So if fuel was coming out of that hole it means that your float valve or float on that carb was not working correctly. A piece of debris in the fuel line above the float valve can cause the valve to not operate correctly or they could have been defective.
I would not get rid of that fuel pump just yet.
Charley
F
Federalees
Interesting, and this makes sense. But mine had/has a thin paper gasket only.
F
Federalees
Charley
Thanks Charlie,
Yep. I am aware of the overflow hole’s purpose. This is why I checked and replaced the needle valve and float first. As stated in my original post, this was not the problem and I was surprised by that. It was definitely the fuel pump, but I am still keeping the old one.
F
Federalees
Just curious, how are you guys checking fuel pressure?
I used a fuel pressure tester tool. Super easy to use. Connect the vacuum line from the tool to the output side of the fuel pump and crank the engine for a few seconds.
D Forum for Triumph TR6 only FORUM Navigation Questions 2
Lin New Forum Upgrade Question Austin Healey 8
luke44 TR2/3/3A The “old” forum Triumph 2
Michael Oritt This forum Austin Healey 20
steveg Healey forum showing > 1000 logged in FORUM Navigation Questions 6
Rut Dinner with forum friends Spridgets 15
njunear Newbie - to this forum, that is........ Austin Healey 8
Basil Admn Note Cool new modification for the Triumph forum Triumph 7
Basil Admin Note Cool new modification for the MG forum! MG 3
NutmegCT Forum search FORUM Navigation Questions 2
BLong63AH New to Forum Austin Healey 22
nevets How do I unsubscribe to a forum thread??? FORUM Navigation Questions 2
CJD TR2/3/3A Take that, Forum! Triumph 2
Boink Waterless Coolant - thread from the AH forum Spridgets 18
B [UK] Healey Forum Austin Healey 4
mgbmedic T-Series Return to Forum / MGTF Restoration MG 6
T TR4/4A Thank you for this forum! Triumph 2
J TR2/3/3A British Car Forum and The Triumph Experience? Triumph 18
S General Tech Body men on other" the car forum Triumph 1
R MGA Experience buying an MGA from a US Vendor - Vendor Review forum? MG 8
vette Is it my computer or a New forum Format. Austin Healey 7
R Hello, new to the forum and new to Austin Healey. Austin Healey 31
Z New forum participant - once I find a car! Austin Healey 61
certifiedcarnut Are there any spridget forum members who live on maryland's eastern shore? Spridgets 1
tomshobby Thanks to the members of this forum. Spridgets 8
R New to Forum and Excited to start restoration on my New AH 1964 Sprite Austin Healey 6
P A Mighty Forum Austin Healey 7
W Another Bugeye forum Spridgets 5
A Posting in a marque-specific forum FORUM Navigation Questions 1
Lukens TR2/3/3A Thanks to the forum and specifically a member. Triumph 4
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
T TR4/4A Belated Happy New Year, glad to be back on the forum, and have a starter question... Triumph 27
K TR2/3/3A Trunnion replacement done....Thanks to Forum Triumph 3
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
BobbyD Off Topic HiJacked Forum Link? Triumph 4
Basil Admin Note New Prefix Feature in MG forum MG 2
glemon Forum Suggestion, Lister's Name FORUM Navigation Questions 1
Jim_Gruber 210 5 Speed listed on Bugeye Parts Forum Spridgets 1
F Forum help FORUM Navigation Questions 3
B VTR Forum Triumph 1
J Having trouble getting Forum to work on IE 9 since it was switched to the new format. FORUM Navigation Questions 7
Lbp TR2/3/3A New to Forum, New TR3 Owner, Dashboard Question Triumph 8
P MG Forum wither away? Spridgets 8
Hap Waldrop wrong forum, opps, Spridgets 1
Basil Forum Tutorial Videos FORUM Navigation Questions 0
me61ic Forum search and Door Check Strap ? Austin Healey 1
T Intro new to Forum TVR 10
G hi all - new to the forum ... got questions ... Austin Healey 10
S Spitfire New to forum and owning a spitfire and need help Triumph 16
S Stuck again on the other than British car forum Triumph 0
