New Starter Installation
BobbyD
Folks.....I just updated my site with the installation of Ted Schumacher's gear reduction starter. Quality product and a great price. The TR6 starter can be a PITA to install due to limited access of the top bolt/nut. I came up with a pretty simple way of doing it that made it an easy one person operation. You can see it here https://tr6.danielsonfamily.org/Starter.htm
T
Tinster
Hey Bob!!
Nice layout!!
I like your skinny wrench with bend and thin metal weld.
I've got a few skinny wrenchs I've ground thin but the bend
and thin metal weld is a valuable technique.
And yeah, I recently installed a standard TR6 starter
by myself and it IS a bear to get in.
Thanks much,
dale
donbmw
I hope you removed the allen head bolts tha hold the start to adapter and loctie them. You can go a short time or as long as about 4 years before you hear the starter sound funny whe starting or it wont start at all and only hear the starter turn.
Don
go_inbroke
I like a guy who can think outside of the box. Great job!
TR3driver
Great Pumpkin - R.I.P
Dunno if this applies to the TR6, but on my TR3A I finally put a Heli-coil into the bellhousing so I no longer had to deal with that dang nut. Made the starter R&R much easier.
I liked the mod so much that I copied it to the TR6 gearbox I put in later. That time I did it with the gearbox out of the car, but the first time I just ran it in through the opening in the engine block. No doubt the special tap left some threads in the block, but they don't hurt anything
Trick6
I switched my stock starter for the gear reduction one when I upgraded to a 6-3-1 header and tri carbs - the entire passenger side of the motor was exposed so why the heck not. I wish I had the BobbyD tricks then. I found that there was a certain way to hold your mouth to get that top bolt fastened. I tried other expressions but it was just the special one that got it done.
DNK
<span style="font-size: 26pt">HEY</span> I didn't get the female part of the locking spade connector.
V Wedge tr8 starter installation question Triumph 11
2wrench TR6 Help with TR6 starter installation. Triumph 19
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
