I was experiencing major overheating problems with my car and decided this summer to have a new radiator custom built by chuck @ antique radiators in maine. My 67 BJ8 was experiencing overheating issues (that we all face)...
Some interesting points:
- the new radiator weighs about 20 lbs heavier than origianal radiator - due to materials and density
- previously in 70 degree weather my car continously ran 185+ and when sitting at a light would go 190+... this is with a 160 degree thermostat installed.
- when discussing the new radiator, they quoted 20-30% more efficient than existing radiator design.
- and now... the car runs (70 degree day) between 160-165 - exactly where the thermostat wants it to run. you can actually see the temperature drop from 160 down to 150 then crawl up when the thermostat opens up fully. Sitting @ a light it will go up to 165-170, then drive about a mile and it comes right back down.
- I know 160 is not the ideal operating temp for these cars, 180 is better, but now i believe i can truly switch out the thermostat with a 180 and have the car operate @ 180.
- it will be interesting to see what it does during the summer - 90+F.
- also - side note - when discussing with Chuck @ antique radiators - he recommended not using a texas cooling fan for front as it reduces airflow through the radiator and that a good radiator design should allow the car to run normally even when stopped.
Anyway - the workmanship is unbelievable - radiator looks brand new - and looking at it from front/back/sides you cannot tell it's using new & improved technologies, etc. inside the radiator... so it looks 100% original...
*** Even better - the interior of my car is not so hot when driving around ****
Pretty cool!
Pretty cool!
Hi Guest!
