Keoke
Brandon, why did you remove the servo if you did not know it was bad?. First hold the servo close to you ear and shake it you should hear the fluid sloshing around inside if it did not all leak out after you loosened the screws.There should not be any fluid in the vac chamber of the booster. The rebuilder suggested to you earlier by Scot is excellent and reasonable.---Keoke
