tosoutherncars
Just be sure to hone the cylinder, if you're rebuilding... if it has worn the cylinder wall smooth, a new seal won't have anything to seal against.
tosoutherncars said:Just be sure to hone the cylinder, if you're rebuilding... if it has worn the cylinder wall smooth, a new seal won't have anything to seal against.
JPSmit said:when you rebuilt the MC, did you take off and clean the two fittings on the side (where the actual brake lines go) I was stunned how much crud there was in mine when I rebuilt the MC
highhilleer said:Bummer!!! Spent the weekend on the brakes doing:
rebuild MC
rebuild both calipers
replace front and rear hoses
replace disc pads
inspect rear brakes - pleaty of material on shoes, no leaks of cylinders
adjust rear brakes
adjust parking brakes
bleed and rebleed the system
All to no avail - I could tell backing the car out of the garage that the brakes just do not grip. A short trip through the neighborhood confirmed scarry brakes. A lot of pedal pressure will get the car to stop and there is no pulling to one side. The stroke of the pedal seems ok and the pedal is firm at the end of the stroke without bottoming out. It just takes too much force on the pedal and too much distance to stop. Haven't found any leaks and the MC stays full.
I'm thinking the pressure differential valve (shuttle) may be the problem as spritenut suggested. The brake light is not lit, but it doesn't come on with the parking brake engaged, so I think I have another problem with the light. I tested the continuity at the back of the pressure differential switch and got a signal. I believe this means the switch has been activated. I haven't been able to get the switch to center by bleeding so I'll pull it tonight and see what is up.
I would appreciate any comments/suggestions
Thanks
John
sparkydave said:Hi John, FYI, to center the PDWA valve on a 1500, I have found the service manuals were incorrect, at least it was for mine. I had to unscrew the switch from the body to get the shuttle to center. No, I don't know why that is the case, but when I took mine apart, I found the shuttle has a flat ridge that the switch rides on, and once the shuttle moves, the switch pushrod latches in place and keeps the shuttle from moving. If your seals are in good shape, you can unscrew the switch from the body without leaking. Also there are springs on the shuttle that will center it once you do that, so you don't need to follow the service manual procedure. I can only assume there was more than one style of PDWA that was in use, because the pictures of the PDWA shuttle in my service manual show a groove in the center where the switch sits, and mine has a ridge. Hope this helps!
