    Thanks and welcome to BCF!
New member with old problems
JAJohn
Bronze
Hello! I'm restoring a 1961 TR3 with rust everywhere. I discovered my door sills are rotten on both sides, inside and out. I will need advice. First, will MIG welding be useful?
Also, I'm going to replace the frozen engine with a good one. What problems can I expect with removing the front apron/radiator?
I have worked extensively on TR 4 and 4A, but that was 40 years ago! Thanks for advice.
first of all welcome! Sounds like a great project
You are probably better off to repost the questions themselves on the Triumph forum. This is really just the welcome page.
I will go out on a limb and suggest that yes, MIG is good! :grin:
Welcome to the BCF! As JP suggested, you will probably get more answers to your specific questions if you post your question in the Triumph forum.
Cheers!
At the risk of incurring Basil's wrath: Yes, MIG will be very helpful. And by far the biggest problem with removing the apron is all the caged nuts that will spin in their cages if the associated threads are even a little bit rusty. You'll want some needle-nose vice grips so you can reach inside and clamp the cage onto the nut long enough to get the screw out. Removing the headlight buckets will help with the ones in the middle, but again they have captive nuts that tend to spin instead of come out. Fortunately, they are easier to get at with an angle grinder and cutoff blade, to cut the head off so you can remove the bucket and gain access to the nuts.
