I wanted to post a quick introduction. My name is Grover and I am in the Dallas area.
Several years ago I inherited a 1962 Austin Healey 3000 from my Uncle. Black with Red interior, tri-carb, all 3 tops, wire wheels, electric ovedrive. I have the original bill of sale and title. It was his daily driver in Ft Worth for many years. I have fond memories as a child of visting him and getting a ride in the Healey.
The car itself has not run since probably 1995. I had to buy a new house with an extra garage to work on it. Also, kids, moving, life, etc. means that I have not had much time to "get started". I finally pulled it out the other day and spent a week blowing 30 years of road grime off the undercarraige. It's back in the garage and ready for action.
The paint is decent but it's cracked on the hood/trunk. The interior is pretty well worn. The underside seems like it's ok - although I'm sure brakes and shocks need freshening.
My plan is to get it on the road. I'm not looking for a full restoration - as this is a "family car" and will not be sold. Also - I like to drive cars - not look at them. So, I would like to clean it up - but not so much I'm afraid to drive it.
So the plan is this:
-Go through everything mechanical
-Fix the paint where necessary
-New interior
Step 1 is to see if the engine will run.
-Oil and Filter change (researching oil)
-Replace all fuel and clean tank
-Rebuild carbs
-Change spark plugs
-MMO in cyls
-Check compression
-Clean/replace distributor/rotor/coil
-Check spark
-Replace collant/belts
When it's running, I'll work my around the rest of the mechanical bits.
Time for me to start doing some serious research on the forums!
If you're in the Dallas area and want to stop by - I have some cold ones in the fridge.
Grover
-New interior
-Rebuild carbs
-Change spark plugs
-MMO in cyls
-Check compression
-Check spark
Grover
Hi Guest!
Nice car Grover and welcome to the forum. You do indeed have a nice car their to start with. I wish I had a nickel for every guy who's said just what you did. Ha, just kidding, I do know eventually you will completely restore the car.
