New kid on the block!
LearJeff
Greetings! Well, first of all I'm pretty good at following directions. So, when I received my welcome msg. from Basil urging me to post, here I am.
My name is Jeff Perdue and I live in Alameda, CA. (near San Francisco). My current British obsession (other than my wife and two Jack Russell Terriers!) is my little red 1974 Triumph TR6. I'm about 50% through with the biggest project of my life - a 100% body-off frame restoration. I delivered the car to my frined & mechanic, Steve, in late February of this year and the body was off, engine, transmission and rear diff were removed, as well as all the front and rear suspension pieces and all other remaining components by March 1, so I consider that our true "ground zero" start date.
One thing we're doing that may set this car apart is the vast amount of powder coating. EVERY metal piece of the undercarriage was sent out for powder coating and I do mean every piece! From the biggest of items such as the frame itself to the tiniest items, like the small metal clips that hold the fuel line secure to the frame. All powder coated. The frame is finished in a beautful silver, which provides a very nice contrast to the satin black of all the other metal components. 80 some odd pieces in all were powder coated, most of which will never see the light of day again!
A few other interesting touches include the replacement of every single nut, bolt, washer and screw with brand new, aviation-grade hardware. As each bolt is properly secured, a bright red stripe of Torque Seal will be applied.
And of course, we did the obvious upgrades, shock conversion in the rear, poly-urethane bushings throughout, stiffeners added to the front, rear diff mounting strengthened, etc. We also upgraded and modified the front brakes to Strange Engineering Rotors and Calipers. And Steve designed a rear disc brake conversion using Strange components, as well. Aside from the in-house fabrication of the various mounting brackets, the biggest part of the job was finding a company that would sell us un-drilled or "blank" one-piece rotors. Once Strange agreed to that, Steve came up with a way of adapting the rotors to the existing hubs by way of a tack welded "retainer" ring that filled in the empty diameter around the center of the hub. Sounds easy enough, but getting the rings machined to the tolerances required was probably the most complex part of the job. Then the rotors were drilled to accomodate the Triumph stud-bolt pattern. We are now in the process of trial and error to determine the best way to mount the rear calipers. We have narrowed it down to three possibilities, each with their pros and cons. Stay tuned! We ended up going with a Willwood caliper for the emergency brake.
The transmission has been overhauled, the rear diff overhauled and the engine is due to be delivered next week some time (the week of March 20th). In the meantime, all of the powder coated pieces have been delivered back to Steve's shop and assembly is already underway.
I've managed to come up with a VERY rudimentary web site depicting our progress on the car so far, along with a somewhat interesting history of how I came to own this particualr TR6. The un-original web site name is:
www.jeffperdue.com . FYI--It seems to load relatively slowly, even with DSL. If you have a dial-up connection, you might want to skip it! And, if anyone out there has any recommendations as to what I did wrong with the site in terms of its loading speed, please let me know! Thanks,
Jeff
Wow that should be an amazing "6" ! Seems like things have progressed quickly already-- have a target date?
Welcome!
Jeff:
Things are looking good. You are definitely doing exactly what I wish that I had the time to do and taking pictures is the right way to document the hidden effort as well.
Try using Win XP to compress your images by choosing the image and right clicking and choosing resize picture. You may make it slightly smaller, but it will compress to a much smaller overall size allowing for a faster page load.
And welcome to the forum!
Hi and welcome Jeff,
I'm a dinosaur still using dial up, so haven't seen more than a glimpse of it, but your car sounds like a lot of thought and effort have gone into it! I'm doing a similar "nut & bolt frame-off" restoration/resto-modification of my '62 TR4, which I've owned since about 1977 and actually restored once before around 1979.
I'm particularly interersted in the rear disk brake conversion you installed. I've wondered what might be possible there. If you could expand on it, perhaps in a separate, new thread, that would be great.
As a photographer, I can second what Alan A. says above... Overly large pics and too many of them on single page of a website can make it bog down big time. It's a major mistake I see all over the I'net, especially on car-related sites and in eBay car auctions. Thumbnails help a lot.
According to Photoshop on my computer, your initial image is over 11x8.5" and 180 pixels per inch. On websites I suggest pics no larger than 4x6", smaller if possible and 100 ppi max to make them load more easily. (I use approx. 2x3" & 100 ppi on my online gallery, but do this in part to prevent image theft.)
Some picture handling softwares have automated "web optimizing" features in them that can help prepare photos. However, many of these use 72 ppi, which is better in terms of loading and has been the norm, but some monitors today can use 100 ppi for better image quality.
Have fun!
Welcome Jeff,
That is going to be one fantastic looking car when you are done!
I did notice something in one of the pictures. It seems that you have a metal engine fan that you powder coated. I too have a '74 TR6 and it has a 13 blade red plastic fan. I am fairly sure that all the TR6s used one of two types of plastic fans and never a metal one.
It just a small detail but with all of the effort you are putting into your car I thought you might want to know.
Keep us updated with the progress!
I wish I could see that in person when completed! /ubbthreads/images/graemlins/cool.gif
Welcome to the finest British Car Forum on the Planet.
Your project is one I have always wanted to attempt, but find myself a little timid, (if it ain't broke.....)
I too am interested in your rear disc decisions and am looking forward to watching your progress.
FWIW I'm on the old dial up myself, heck I still have dial phones on every level of the house and garage!
Welcome,
There are alot of GREAT people here, with alot of knowledge
Dang, Jeff. You (along with Alan) are doing what every one of us would like to do! Great job. Now, if you can only post bigger pictures, we can go about finding flaws. Just kidding.
Not only are you restoring, but improving. That, to me, is the way to fly, a true resto-mod.
A word of wisdom, stay away from those hotrodders (myself included) on the forum. They/we will be upping your horsepower next.
Keep us posted on your final product. Can't wait.
Oh, and by the way, my wife has an old uncle in Alameda. Been there more than a few times. A glorious old town with great character. And just a BART ride from San Fran.
Year-round perfect climate.
Bill
Just went back to the site. Glad you fixed the pics...
Now how to we talk you into making it go faster. After all you already said your friend owns a race shop....
Thanks to EVERYONE for all your great suggestions and information. I'm much less timid about just saying "to heck with it, let's try it!" when it comes to my car than my first-attempt web site! How pathetic is that? But, I will look into re-sizing the pictures into thumbnails, I promise! God, I wish I was more computer savvy... I put so much time and effort into that silly web site, I'm almost afraid to touch it for fear of wiping the whole thing out...but I will try, this week!
Thanks again everyone. And, I would like to add my sentiments to those of several others here, this really is an awesome web site!
Jeff
Wow Jeff,
I'm impressed. I just joined the forum also.I have a 74 1/2 red tr6. Bought it new out of the showroom in Michigan. I'm keeping it on the road but don't have the will powewr to under take what you're up to. Great pics. Good luck.
Boston Bob
Top-notch, indeed!
With the superlative effort that you are putting into your restoration, I was surprised to see a standard 4-speed tranny. Definitely spring for overdrive, you won't regret it.
Congrats on setting a very high standard for restoration.
By the way, I'm nearby in Marin County. Despite TR6BILL's claim of a perfect climate, y'all should know that we just set a record for rainy days in March. And it is still raining...
