TR6 new fuel pump
sundown
Hi, This is a follow-up about my fuel pump issues.I just got the new pump it's just like the original.Is there a reason why they discontinue the replacement one , wondering if was failing out in the field. Thanks
poolboy
I don't understand.. What do you mean about discontinuing the replacement ? What you have is a replacement is it not ?
sundown
sundown
Sorry about the bad description what I meant is yes it is a replacement but it is much bigger and and looks more like the original pump than the first replacement I bought some 12 years ago.that one is much smaller. Thanks
poolboy
I hope it solves the problem.
I've seen a couple of different looking pumps mounted on TR6 engines...one was noticeably smaller. My concern was that it wasn't going to pump the same volume as the original AC and the AC reproductions.
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S BJ8 Fuel Pump Austin Healey 13
S BJ-8 SU Fuel Pump Replacement Austin Healey 5
steveg Fuel pump inertia cutoff switch Austin Healey 33
Csarneson Fuel pump options Austin Healey 10
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
Bayless How do you mount a Facet fuel pump? Spridgets 10
Got_All_4 TR6 Fuel pump rebuild, Part not included Triumph 4
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
S T-Series su fuel pump MG 0
M Fuel pump question Austin Healey 3
R Solid state SU Fuel Pump Austin Healey 2
PAUL161 T-Series Hardi Fuel Pump - Germany MG 4
Bob_Spidell Hardi Fuel Pump Austin Healey 39
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
S For Sale fuel pump Pos grd Austin Healey Classifieds 0
NutmegCT T-Series SU fuel pump fun MG 20
NutmegCT Type L SU fuel pump Austin Healey 8
Bob_Spidell BJ8 Fuel Pump Trivia Austin Healey 0
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
sundown TR6 fuel pump Triumph 11
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
M Leaky Fuel Pump and Weak Performance Spridgets 14
