hondo402000
OK, the new crash pad is in, reveneered dash is in, new Glass, dont ask, windscreen frame finished. put all the gauges back in. ooo the heater motor I rebuild over a year ago never blew air, I found out It was running backwards, how did that happen so I replace it with another one I rebuild made sure I check it before installing and it didi run. Now here is where I am at, fan blower does not work, temp gauge acts like a fuel gauge( should be easy to swap wires)so I assume fuel gauge is acting like the temp gauge, Ignition lite glows when Ignition is off, car starts but wont stop when Ing is switched off, no turn signals and no brake lights. I marked all the wires when I pulled them off the gauges, used the book to make sure I hooked them all back up, I must have pulled some wires loose some where. I hope I can figure it out, but it sure looks good if you have had any troubles like this, please chim in, now I am studying the electrical section of Bentley, I hope I dont have to order a new wiring harness and rewire the whole car, I might shoot myself
