hondo402000
well getting ready to bite the gold coin and get me some new CV joint Half shaft in prep for my engine rebuild this fall that will produce 160 hp at the flywheel
hondo
hondo
Hi Guest!
I installed the 3/8" stud.KVH said:If I'm careful, methodical, and typically worrisome, how long would it take to meticulously drill out those TA stud holes and install the helicoils or other inserts?
Use Patton's kit? What then is the expected or correct torque?
By the way, what is a die grinder and flap wheel, and why was that needed?
Finally, if 3/8 is too big, what size is recommended, 5/16? And for that, what size drill bit?
thx
