T
Tinster
The Crypt Car has been marginally operational for the past
three days. I didn't post anything for fear something new
would blow up or break down. Glad I didn't post good news.
Crypt Car broken down again and going back on jack stands
after only 8 miles of use..
WOW!!! I have driven the car a grand total of 8 miles
since it came down off jack stands. The periods between
Crypt Car break downs are getting smaller and shorter and
shorter. The car is no longer marginally operational.
Now it barely functions as a running engine of any type.
Facts for diagnostics/problem solving:
It's my 58th B-day and Wendy's taking me to a beach
nursing home for old pfarrrrrrrrrrr ts for 4 days.
Timing set at 15*
All plugs in place and new and gapped .025"
New Coil and all ignition wires new
GM alternator new and Dan Masters wired
Petronic ignition new
Paul Rego throttle busings new
Jeff Palya carbs and intake manifold new
Both tiny carb ear tubes in place to dizzy.
Jeff Schlemmer distributor new
Ignition switch new
Battery new
Fuel pump refurbished and functional
New fuel lines with 5 in-line filters-more or less
warm idle at 900 rpm
Operating temperature 160* thermostat.
All ground wires new and many.
Dan Master entire car wire harness Power Block
5 gallons brand new high test gasoline added to new tank.
Nothing changed between yesterday and today other
than I tightened down the rad cap.
The car now backfires something terrible. Thru the
exhaust pipes (I think )
Rough idle now.
The car will not accelerate but bogs down,hesitates
and backfires. I WILL stumble up to higher speeds but
nothing smooth about it.
So what DPO Pedro part I don't know about has broken down
now? I can't image what it might be? Any and all help
appreciated. A broken piston or busted head gasket?
The tail pipes don't throw clouds of smoke.
I know you TR6 gurus will have solved my new problem and
come up with a long list of new parts to order by my return
next week.
Thanks again, /bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif
d
Timing set at 15*
Ignition switch new
Battery new
Rough idle now.
next week.
d
