longbridgehealey
So I've removed the switch, and discovered one of the tabs that you connect the wires to is totally disintegrated. I notice that there are originally four posts to connect to. The wires that are loose are to the starter, via the coil. If I touch these to the post that has the wires for the wipers and turn signal, I get power to the starter. Can I connect here, along with the other wires, or is that too much? I hope this makes sense.
Larry
Larry
