I just bought a 61 TR4 The car is exceptionally preserved with 1 respray. Whoever owned this car before the last owner knew what he had. It has a 5 speed Toyota conversion. I bought it without inspection only from high res images and video. A risk. But I’m blown away, especially how it got to Illinois from Texas during last weeks storms Another whole topic on shipping cars.
But I have an electrical issue. Initislly no turn, wiper, blower or headlights. I checked the fuses and after checking, all working but headlights. The former owner said check the dimmer (dipper). I used a test light and had power at all 3 when light switch is on. The main beam dash stays on regardless of pressing the switch. I have power at the left high and low when the headlight switch is on. But lamp is out, Same on the right.
My assessment is the dimmer switch is bad. The headlight switch works because if I push in to park, I lose test light at the front plugs to the headlamps.
is it possible that both beams are out? Crazy but the car has upgraded alternator.
I’d sure like to track down the prior owner. It has BMH certificate that was issued in 1990.
Thanks
Thanks
Hi Guest!
