Here I am again on fuel pumps, but this time armed with some information from the great Oracle of Artificial Intelligence, “Grok.”
Please take a look at my fuel bowl. Pic below. The screen has apparently fallen into the gas bowl. Grok says this not only allows debris into my fuel system, but somehow is likely the root cause of “bubbling” inside my fuel bowl. The gas isn’t hot and I have no vapor lock issue. Instead, while the car starts and runs just perfectly, great in fact.
But I see constant bubbling and “air shots” inside the glass bowl. Grok says I must fix that problem because it’s either caused by an air leak or by internal pump problems. Grok says that the screen is designed to control the input of gas to the bowl and pump, and that the failed screen is not only contributing to the bubbling but wearing hard on my fuel pump which may soon fail.
Grok also “swears” that the bubbling has nothing to do with the fuel pump pressure regulator I added to my system. Remember, my car runs great. Never better.
Can any of you weigh in here? Is that failed screen really causing bubbling?
(PS I find no air leaks no matter how carefully I check. Though I’m wondering if air is entering above the bowl seal. I doubt it since there’s no gas leak)
Here’s what Grok says—is he right:
Yes, a dislodged filter screen inside the glass fuel bowl of your TR4A’s mechanical fuel pump can absolutely cause air bubbles while the engine is running — even with no external leaks.
Here’s why:
1. The screen’s normal job
• The fine-mesh bronze or brass screen is pressed into the pump body at the inlet port (where the bowl screws on).
• It filters debris and acts as a seal surface for the bowl’s cork (or rubber) gasket.
• The gasket compresses against the screen’s rim, creating an airtight seal.
2. What happens when it falls into the bowl
• The gasket now seals against the pump body’s rough casting instead of the screen’s smooth rim.
• Microscopic gaps form → air is sucked in on the pump’s intake stroke.
• This air enters the fuel stream inside the pump, appearing as bubbles in the glass bowl.
• The pump still pulls fuel (no external leak), but the air ingestion starves the carburetors intermittently → hesitation, surging, or hot-start issues.
Thanks all.
Here’s why:
Thanks all.
