TulsaFred
I've seen two explanations on the internet for converting my B/E from pos to neg ground.
The first explanation says to flash the A or A1 terminal on my Lucas voltage reg to the D terminal. It says not to touch, under any circumstance, the F terminal or it can damage the regulator.
The second explanation says to disconnect the two terminals on the generator itself, then to flash the smaller "field" terminal with a hot lead.
These two sets of instructions seem inconsistent.
Which is correct?
BTW, can anyone elaborate or show a pic of the "Field" terminal on a B/E tach drive generator?
thanks
Fred
Which is correct?
thanks
Fred
