scoobiedoo
I have a 75 Midget that appears to have a spit engine in it (points ignition, different "Temperature compensator" mechanical choke)
I bought a rebuild kit for a Midget and it dosen't have the proper gasket for the mechianical choke unit. I was wondering if anyone knew of a source for this single gasket.
Also the "temperature Compensator" and "bypass valve", what ate their functions? I assume they are part of the idle air control system but am a bit foggy. My temp comp plastic valve peice is pitted and cant fully seat and seal, is this a serious problem? And finally my bypass valve appears to have been sloders in such a way as to make it stay closed, would this cause it to not idle?
