Need immediate help with Bugeye fuel tank
ncbugeye
As I type with oily hands, I am trying to remove ncbugeye's fuel tank to have it boiled.
I have all the 1/2" nuts undone all the way round, 6 of them.
I have the fuel pipe union detached at the right front of the tank.
It will move, and sort of rotates around the right rear corner, but it won't come down. Something at right rear is holding it up there.
What is it?
healeyboz
Filler neck or sending unit wire? If not it is caught on the threads of the mounting bolts.
Platinum
Wish I had a clue, Chris, but my last Frogeye resto has been too many years back to have any recollection of the specifics. Hopefully Jack or another who's done it recently will pap up soon. Tim's suggestion seems the likely suspect.
sorry!
jlaird
Bolts around tank, fuel line, filler pipe press fit. That's it.
Bugeye58
Chris, it definitely sounds as though it's hanging up on the threads of the mount stud. If you can, try to drop it down as straight as possible. A little judicious prying may help if all else fails. There shouldn't be anything else holding it in at this stage.
Jeff
ncbugeye
ncbugeye
It was the "straight as possible" that I wasn't doing. I had it slightly caddy-cornered as I was trying to pull it down from underneath, and it clearly wasn't working. I pushed it back on to the studs and then pushed down directly on the filler pipe from above, and down it came. Voilà.
OK, so I have it out and the sender unit removed, (boy those six screws were tight) and the sender unit looks almost as new - absolutely corrosion-free, and the inside of the tank looks almost completely rust-free. Is this possible? This is definitely the original tank as the fill tube has the red paint from when the interior was roughed out with red in the factory.
I had heard that this was a must-do for a car that still has its original tank from 48 years ago...
Bugeye58
It's entirely possible Chris. I've got an original tank here that is bright shiny metal on the inside. Not all fuel tanks are rusty piles of caca.
Jeff
ncbugeye
ncbugeye
I think not, this paint is ONLY on the middle section of the filler tube, i.e. it covers that part of the filler tube that was accessible inside the cave. Interestingly the cave was very clearly brush-painted, not sprayed, including the filler tube, to the extent that the extreme upper rear part of the tube, which was clearly hard to get to with a brush, was missed. I would imagine that painting the cave on these bodies was a task given to the ones who were still "wet around the ears" as there was probably a fair amount of noxious fumes in there while doing that job.
regularman
That is awesome. I would just put it back on then. There should not be much junk in that tank. I bought an add on fuel filter that you can take apart and clean at an auto parts store and put it in the line right before the filter. Even though I coated my tank, I figure that it couldn't hurt.
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
