Just a small point on the screw's. You can't beat having a impact screw driver in your tool chest. A screw can be pretty mangled and still come out. Also using one elimates buggered scew heads!
KA.
OK, so here I am. I've got the front brakes tore down, and I'm staring at totally ripped and torn up rack boots. So to replace them, I need to get into the tie rod, right??? The tie rod end has to come off, right? And in order to do this, I've gotta take off the steering arm, right??????? So if all of this is right, can I start at the steering arm, take it off, then the tie rod ends? How do I deal with the tab washer at the steering arm?
When I replaced the rack boots on my Bugeye I just unscrewed the tie rod ends from the rack arms... Then the new boots just slide right on...
I made a note as to how many turns to remove the tie rods, so when I put it back together it was close where they were before I started. I needed to do an "alignment" any way.
One other thing make sure you get the correct boots - later model boots do not work. I got mine from VB...
cd
