Re: Need Help with a "THREAD SIZE"/Chasers
OK, now I'm really interested.
In the past, I've looked for thread chasers, and called the local tool shops. The only shop who knew what they were had a set in stock for $180. I passed.
I didn't call Sears or check McMasters, but clearly I should have. I believe I did call Harbor Freight to no avail.
More importantly, I have been "stressing" a bit about using taps and dies to fix some of the preset threads in the body of my TR4A. For example, the threads in the preset, welded nuts in the floor boards seemed very irregular, and the bolts just would not go back in smoothly.
Same problem for a preset nut up under the dash.
I then had problems with the two preset nuts in the radiator support bracket in the front of the car, and the same problem with a nut for the front crash tube/brace that guards the engine.
For all, I used some cutting oil and very carefully (gently) reworked the threads with a standard tap. Everything seemed to go back together well and tight. However, I did note a slight bit more play in the bolts as I finger-tightened them in. Bothered me a bit.
Can I stop losing sleep?
