TR6 Need Help on 71 TR6 Overdrive Wiring
hondo402000
I have an A type over drive transmission going in when my engine gets back, I am in the process of replacing the front wiring harness and I am trying to figure out how to wire the OD, the challenge is in the wiring diagram for a 71 TR6, in the optional overdrive box in the corner of the diagram shows and says a N(brown wire) W(white wire) from fuse box. the question is where do they plug in to the fuse box. Would they plug in to the same locations of current White and Brown wires? I know they are both provide power to the OD circuit, the white looks like it engergises the relay coil and the brown wire pulls the solonoid in(which pulls more amps)
any help would be appreciate(Wayne)
Hondo
angelfj1
Hondo
Hondo: The simplest approach - solid brown - un-switched and un-fused. Connection points are your fuse box and ammeter. White is ignition - un-fused and switched by ign switch, you can tap at fus ebox or back of ign. switch.
Be sure to say 'hey' to all of my TCC friends (the old f-arts) who might remember me - founding member #4.
good luck
TR3driver
Great Pumpkin - R.I.P
I suggest adding a fuse to at least the brown wire.
The solenoid used on the A-type OD has two internal coils, a pull-in coil and a holding coil. The pull-in coil draws close to 20 amps, but is supposed to operate for only a fraction of a second each time the solenoid is engaged. Normally when the plunger hits bottom, it presses an internal rod that opens some contacts hidden under the end cap, taking the pull-in coil out of the circuit.
If for some reason that doesn't happen, like the solenoid is misadjusted, or the lower stop falls out, or even a piece of rock finds it's way inside the solenoid; the pull-in coil will quickly burn up and ruin the whole solenoid. Replacements were not cheap, last time I looked. I have also once had the little plastic pushrod break, which would have been easy to replace if the coil wasn't burned up.
But with the in-line fuse, instead of the solenoid burning up, it will just pop a 50 cent fuse.
I use a MDL-8 (8 amp, slo-blo) just because I've got a box of them. But I believe an ordinary fast blow 5 amp (eg AGC-5) will work as well.
HerronScott
Hondo,
Not sure about the TR6 but for the TR4A I thought that the connections for the relay were already in the harness and you just needed to buy/find an overdrive subharness?
Scott
hondo402000
hondo402000
Scott
the OD switch on the column plugs into the separate OD harness 2 wires go to the fuse box and the rest go to the switches on the transmission. So nope on the TR6 its totally separate
Hondo
DNK
Hondo, There is no relay for the A type overdrive?
HerronScott
Hondo,
Not sure if this helps but this was posted on vtr.org regarding the electrical wiring for installing an overdrive.
" Next I mounted the overdrive relay. Since my car already had two relays (horn and hazard flasher), I put the o/d relay next to them (on the sidewall next to the wiper motor). The wiring diagram in the Bentley manual is good here, except that it just shows both the brown and white wire going to the fuse box, without telling you where to connect them. The brown wire goes to a fuse box terminal that is always hot, while the white wire attaches to a switched fuse terminal only hot when ignition is ON). "
There's more here on the rest of the electrical connections as well (no pictures unfortunately).
VTR TR6 A-type overdrive installation
I did find this picture showing the overdrive relay and horn relay mounted but that doesn't really help you with the connections on the fuse box.
Scott
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
L TR6 need help on long dead TR6 Triumph 16
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
2wrench TR6 Need help with '74 TR6 speedometer. Triumph 12
I TR6 Need help on 69 TR6 glove box info Triumph 0
I TR6 Boring subject, but still need help TR6 trim rings Triumph 6
I TR6 Need more headlight help, TR6 Triumph 4
F TR6 Need help w/TR6 oil cooler install... Triumph 16
DNK TR6 Need help with a TR6 Tunnel lamp Triumph 12
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
C TR6 I need a little help....quick measurment on a TR6 Triumph 2
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
boxofparts TR6 Tr6 Down Draft Webers - need help Triumph 2
G TR6 Need help on tr6/250 top install Triumph 4
H TR6 TR6 Timing- Need help please Triumph 2
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
Slider748 TR6 Help - need dimension of front end clearance [TR6] Triumph 3
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
