mightymidget
What I would call the center bolt in the 1/4 leaf spring.
It is at the end of the stack where it mounts in frame of car.
When trying to take apart leaf springs for a rebuild. I attempt to loosen the nut on the center pin but it spins so I cann't remove the nut from pin. I tried to hold the round end with the vise grips, but of course vise grips will not hold pin and it spins off, I was afraid also of doing damage to center pin head.
Also I have remove spring hanger/brackets nut,bolt and sleeve, but the hanger bracket seems attached to spring? how do you remove these. Will they come out once I remove the center bolt previously mentioned?
Hi Guest!
