TR2/3/3A Need Help Identifing Tranny with Overdrive
Chuck Murphy
My friend acquired a tranny with overdrive for a TR3A - but I think it is for something else (TR6??). Can you help identify it?
Tranny: numbers on case are 306812 WYE E336/R. Fluid filler hole on top not drilled - fluid is filled thru plug on side on tranny; three switches on top (2 for OD and 1 for reverse light??); no bosses on sides of tranny like on my TR3A.
Overdrive: numbers are 221 61985/ 005963B. Looks like OD on my TR3A but brass name plate is on side on OD rather than on top of unit.
Chuck
TR3driver
Great Pumpkin - R.I.P
The 61985 would indicate that the overdrive is from a 71-72 TR6. Should be a number stamped on the case near the clutch lever that identifies the main gearbox (which may or may not match the OD, I have a TR4 OD on the back of my TR6 gearbox).
Should work in your friend's TR3A, but there will be a few adjustments to be made. Slot the holes in the crossmember, make longer studs, that sort of thing. I had to shorten the clutch pushrod.
PS, if your buddy's TR3A is early enough to have the filler on the top; then he will also need to modify the transmission tunnel to clear the starter bulge on the TR6 gearbox. It is possible to keep the filler hole by either adding the hole to the TR6 top cover, or what I did was rebuild the TR3A top cover with the TR6 shift rods & forks. If your friend opts to keep the TR6 cover, then he'll probably want to modify it to accept the TR3 shift lever (just drill out the holes on side of the shift tower).
Gearboxserialnumber_zpsb8268f06.jpg~original
PPS, I'm kind of sorry I didn't run the wires to the backup light switch. A backup light was available as an option at the time and there have been several times that I wished I had one.
Tybalt
Chuck, that 306812 number is a casting number. The transmission serial number should start with a "CC" or "CD" and be stamped either on the clutch cross shaft boss as shown in TR3driver's post or if it is out of a later TR6 it may be on the bulge for the starter on the other side of the transmission case.
TR4nut
Chuck- some other visual clues for a quick check - is the output flange round or square - round would be a later car such as a TR6, and possibly a TR4A, square would be something like a TR4. No boss on the side of the case says 4 syncro. Input shaft, if it sticks out past the bellhousing flange is pre TR250 I think- TR6 gearbox would have the input shaft shorter and within the bellhousing.
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
D Need help please Spridgets 4
