TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest.
2wrench
Need help finding gear shift lever spring retainer, please -- HVDA install up-date.
Fellow Forum Members: My HVDA project is progressing slowly, but well. Ready to button up tranny install, but found a horribly worn, beyond use,
gear shift spring retainer.
This is for a 1974 TR6. The part is the domed shaped cap that goes directly down onto the spring that slides over the gear shift lever.
Current suppliers are not providing this part. It is described as N/A.
I post the following to further identify the needed part: https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=32768
The part number is: 848-170, "Key" item 5.
I believe I can buy this part from wayyyyy across the pond, but I am anxious to complete the HVDA installation. Please let me know if anyone
has a handle on this part.
Lastly, I did see a complete "gear shift unit" on Ebay for $109. Sounds like I am buying parts I don't need there.
If anyone can be of help, please let me know.
Dennis
charleyf
Re: Need help finding gear shift lever spring retainer, please -- HVDA install up-date
Yes that part in all the TR3-6 is the same. Likely the same for TR 2 as well. I Found one on eBay for a TR3 shift lever to put on a TR6 tranny.
Charley
Geo Hahn
I noticed that the Moss part number is different for TR4 vs TR6 but that may just be a matter of you have to drill an extra hole or you end up with an extra hole.
Geo Hahn
Oh, and that eBay listing has a 'make an offer' option. Since the dude has 4 of them available I would be tempted to offer a bit less. I have had success with the 'offer' option on eBay and the seller can always counter-offer if you aim too low.
philstr6
Dennis
have you found your part yet,if not pm me your address and I will send you one
Philstr6
Phil
2wrench
2wrench
Thank you so much, Phil. I am excited! I have sent you my mailing address. If there are parts costs or shipping costs, please let me know.
I am anxious to move forward. Your help is greatly appreciated.
To all Members, thank you for your support.
Dennis
2wrench
2wrench
<img src="https://www.britishcarforum.com/bcf/attachment.php?attachmentid=39127&stc=1" attachmentid="39127" alt="" id="vbattach_39127" class="previewthumb">My new transmission awaiting parts.  Sorry, I didn't know how to rotate this picture.   Dennis  <img src="images/smilies/fat.png" border="0" alt="" title="Fat" smilieid="134" class="inlineimg">
2wrench
2wrench
Dennis
Philstr6
Phil
Did you receive my PM with address? Looking for confirmation if the part was sent. Again, advise if there are costs. Thanks.
philstr6
Dennis
parts in the mail,sent on monday you should see it on weds or thrusday
Phil
B TR4/4A Need Help Finding Triumph 3
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
S I need help finding a correct bolt. Austin Healey 8
F Need help finding a part- door window track piece Austin Healey 5
T longer wheel studs need help finding Triumph 11
Cyberpyr8 Need help finding a solution Triumph 23
S Need Help Finding a Part Austin Healey 1
KLUTZ MGB-GT Need help finding Previous, Previous owner 74.5 GT MG 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
